[GRASS5] error in v.example for grass61
Markus Neteler neteler at itc.it
Thu Mar 9 15:45:50 EST 2006
Marcos,
thanks for the hint, fixed.
Markus
On Thu, Mar 09, 2006 at 09:00:38PM +0100, marcos boullón magán wrote:
> Please,
> Could someone with write access to grass61 CVS update the v.example code?
> In line 49, file
> grass6/doc/vector/v.example/main.c
> please change
> Vect_check_input_output_name ( inopt->answer, outopt->answer, GV_FATAL_EXIT );
> to
> Vect_check_input_output_name ( old->answer, new->answer, GV_FATAL_EXIT );
> Thanks
> -- marcos boullón magán
