[GRASS5] Re: [bug #4155] (grass) d.m will not display remotely
Glynn Clements
glynn at gclements.plus.com
Thu Mar 9 19:15:40 EST 2006
Kirk R. Wythers wrote:
> >> this bug's URL: http://intevation.de/rt/webrt?serial_num=4155
> >> GRASS 6.1.cvs (minnesota_utm):~ > gis.m
> >> X Error of failed request: BadAtom (invalid Atom parameter)
> >> Major opcode of failed request: 20 (X_GetProperty)
> >> Atom id in failed request: 0xb5
> >> Serial number of failed request: 11
> >> Current serial number in output stream: 11
> > I'm guessing that this is an issue with "wish". It's impossible to say
> > any more than that based upon the above details; atom 0x5b (91) isn't
> > predefined (only 1 through 68 are predefined).
> > Can you run wish by itself (or any other Tcl/Tk programs) remotely?
> I hate to have to sound this stupid but you can't hide from the truth...
> I'm not sure what you mean by run wish. I tried the following:
> truffula:/usr/include kwythers$ wish8.4
> Major opcode of failed request: 18 (X_ChangeProperty)
> Serial number of failed request: 12
> Current serial number in output stream: 15
> If that is what you meant, it looks to be the same error as d.m gave
> from GRASS.
That's exactly what I meant.
> Also, can you suggest a simple tcltk program to try remotely (an
> equivalent to xclock)?
Not offhand, although that is no longer necessary.
The problem applies to running wish (the Tcl/Tk interpreter), and will
affect all Tcl/Tk programs. There isn't anything that d.m or gis.m can
do to work around it.
