[GRASS5] v.out.ogr and v.external does not work
Jachym Cepicky jachym.cepicky at centrum.cz
Fri Mar 10 09:58:58 EST 2006
Hallo,
I try to "v.out.ogr" some polygon map from GRASS to PosgreSQL (postgis),
which I do trough
GRASS: ~> v.out.ogr input=det at idrisi type=area  dsn="PG:dbname=krtiny"  olayer=det format=PostgreSQL
After that, two tables (one table and one sequence) are created:
psql=> \d det
   Column     |        Type       |                       Modifikátory
 ogc_fid      | integer           | not null default nextval('public.det_ogc_fid_seq'::text)
 wkb_geometry | geometry          |
 cat          | integer           |
 cislo        | integer           |
 plocha       | double precision  |
 vymera       | double precision  |
 kvalita      | integer           |
 katastr      | character varying |
 ku_kod       | integer           |
 sk_parc      | character varying |
 oddeleni     | integer           |
psql=> Sequence "public.det_ogc_fid_seq"
krtiny=> Sequence "public.det_ogc_fid_seq"
    Sloupec    |   Typ     |   Typ    | Vlastník
 sequence_name | name      | tabulka  | jachym
 last_value    | bigintseq | sequence | jachym
 increment_by  | bigintmns | tabulka  | jachym
 max_value     | bigint    | tabulka  | jachym
 min_value     | bigint    | sequence | jachym
 cache_value   | bigintys  | tabulka  | jachym
 log_cnt       | bigint    | tabulka  | jachym
 is_cycled     | boolean   | sequence | jachym
when I try to "v.extrude" this table, I get following error:
GRASS: ~> v.external dsn="PG: dbname=krtiny" out=det  layer=det
ERROR 1: ERROR:  column "fid" does not exist
ERROR 1: ERROR:  column "ogr_fid" does not exist
Vytvářím topologii ...
Feature:    0
Topologie byla vytvořena.
Počet uzlů          :   0
Počet primitiv      :   0
Počet bodů          :   0
Počet linií         :   0
Počet hranic        :   0
Počet centroidů     :   0
Počet ploch         :   0
Počet ostrovů       :   0
GRASS: ~> d.vect det
WARNING: 'vector/det/head' was found in more mapsets (also found in
         stromy).
The bounding box of the map outside current region, nothing displayed.
What to do?
Thanks
Jachym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/
OFFICE:
Department of Geoinformation Technologies
LDF MZLU v Brně
Zemědělská 3
613 00 Brno
e-mail: xcepicky at node.mendelu.cz
URL:    http://mapserver.mendelu.cz
Tel.:   +420 545 134 514
