[GRASS5] v.out.ogr and v.external does not work
Jachym Cepicky jachym.cepicky at centrum.cz
Fri Mar 10 13:21:39 EST 2006
I upgraded to postgis-1.1.1 and seems to work
only error, i get is
ERROR 1: ERROR:  column "fid" does not exist
but it is running so I'll let it be
jachym
On Fri, Mar 10, 2006 at 03:58:58PM +0100, Jachym Cepicky wrote:
> Hallo,
> I try to "v.out.ogr" some polygon map from GRASS to PosgreSQL (postgis),
> which I do trough
> GRASS: ~> v.out.ogr input=det at idrisi type=area  dsn="PG:dbname=krtiny"  olayer=det format=PostgreSQL
> After that, two tables (one table and one sequence) are created:
> psql=> \d det
>    Column     |        Type       |                       Modifikátory
>  ogc_fid      | integer           | not null default nextval('public.det_ogc_fid_seq'::text)
>  wkb_geometry | geometry          |
>  cat          | integer           |
>  cislo        | integer           |
>  plocha       | double precision  |
>  vymera       | double precision  |
>  kvalita      | integer           |
>  katastr      | character varying |
>  ku_kod       | integer           |
>  sk_parc      | character varying |
>  oddeleni     | integer           |
> psql=> Sequence "public.det_ogc_fid_seq"
> krtiny=> Sequence "public.det_ogc_fid_seq"
>     Sloupec    |   Typ     |   Typ    | Vlastník
>  sequence_name | name      | tabulka  | jachym
>  last_value    | bigintseq | sequence | jachym
>  increment_by  | bigintmns | tabulka  | jachym
>  max_value     | bigint    | tabulka  | jachym
>  min_value     | bigint    | sequence | jachym
>  cache_value   | bigintys  | tabulka  | jachym
>  log_cnt       | bigint    | tabulka  | jachym
>  is_cycled     | boolean   | sequence | jachym
> when I try to "v.extrude" this table, I get following error:
> GRASS: ~> v.external dsn="PG: dbname=krtiny" out=det  layer=det
> ERROR 1: ERROR:  column "ogr_fid" does not exist
> Vytvářím topologii ...
> Feature:    0
> Topologie byla vytvořena.
> Počet uzlů          :   0
> Počet primitiv      :   0
> Počet bodů          :   0
> Počet linií         :   0
> Počet hranic        :   0
> Počet centroidů     :   0
> Počet ploch         :   0
> Počet ostrovů       :   0
> GRASS: ~> d.vect det
> WARNING: 'vector/det/head' was found in more mapsets (also found in
>          stromy).
> The bounding box of the map outside current region, nothing displayed.
> What to do?
> Thanks
> Jachym
> Jachym Cepicky
> e-mail: jachym.cepicky at centrum.cz
> URL: http://les-ejk.cz
> GPG: http://les-ejk.cz/gnupg_public_key/
> OFFICE:
> Department of Geoinformation Technologies
> LDF MZLU v Brně
> Zemědělská 3
> 613 00 Brno
> e-mail: xcepicky at node.mendelu.cz
> URL:    http://mapserver.mendelu.cz
> Tel.:   +420 545 134 514
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Jachym Cepicky
OFFICE:
LDF MZLU v Brně
Zemědělská 3
613 00 Brno
