[GRASS5] JGrass 2.0 released
Andrea Antonello andrea.antonello at gmail.com
Sun Mar 12 17:23:42 EST 2006
Hi Maciek,
> Drainage enforcement was another thing I was asking:
> I wrote:
> > > > > Filling sinks is one of the things I mean. The other is
> > > > > drainage enforcement. Does JGrass provide it?
> > Or better, could you explain exactly what you mean by that?
> Something like r.carve in Grass 6.1 is supposed to do (not functional
> yet).
> Or the CatchmentSIM:
> http://www.toolkit.net.au/catchsim/index.htm?Overview/WatercourseInterp/Wat
>erCFrame.htm~mainFrame
> CatchmentSIM's interpolation method is poor and limited (eg. doesn't
> accept elevation points), but the drainage enforcement is cool.
> Another tool I know which provides drainage enforcement in Anudem.
Alright, I got you. We do not have exactly something like that in JGrass. What
we have is a tool that modifies the dtm following a given network. For
example we need that in flatlands, since in that cases the network is not
well defined. We give a network path and the module modifies the dem and the
drainage directions to define the elevation model in a way to follow the
given network.
Ragards,
Andrea
____________________________________________________________________________
HydroloGIS - Environmental Safety Modelling
www.hydrologis.com
Andrea Antonello
Environmental Engineer
mobile:  +393288497722
"Let it be as much a great honour to take as to give learning,
if you want to be called wise."
Skuggsja' - The King's mirror - 1240 Reykjavik
