[GRASS5] rasters?
Mon Mar 13 01:01:04 EST 2006
Andrea Antonello wrote:
> we from the JGrass project have a problem with raster reading in the new GRASS
> releases. Since end of 2005 some people reported problems with raster
> reading.
> I'm trying to track the problem down, but I really need some help. The bux
> happens on the raster row decompression.
> Markus already helped me with a bugfix that was made by Glynn on compression
> of CELL files. That could one part of the problem but the bug happens to us
> also in the FCELL case. Since the code is pretty complicated I would like to
> collect some ideas before I dive into it, risking to get some more white
> hairs.
What are you asking, exactly?
GRASS floating-point rasters are encoded using XDR, then (optionally)
compressed with zlib.
For data which is compressed (according to the "compressed" field in
the cellhd file), each row begins with a flag byte which indicates
whether the data for that row is actually compressed; a value of 48
(ASCII code for '0') indicates uncompressed data, 49 (ASCII code for
'1') indicates compressed data.
For uncompressed data, there is no flag byte.
