[GRASS5] One more thing related to layers
Radim Blazek radim.blazek at gmail.com
Mon Mar 13 04:29:18 EST 2006
On 3/12/06, Trevor Wiens <twiens at interbaun.com> wrote:
> I'm starting to think about who to update the layers documentation. I
> know that every geometry object within in one layer can have one or
> more categories. Can it also have none?
Yes. For example boundaries usually dont have a category.
> To use the forest / lake
> example. Is it possible to have a lake virtual layer in which only
> lakes will appear and forest virtual layer in which only forests
> appear? AFAICT this would require having some geometry objects having
> no CAT values in the corresponding layers where they shouldn't be
> visible. Is this correct?
In the forest layer appeare only forests and and in lake layer only lakes.
No need/impossible to use objects without category. If you add an object
without a category it will not appeare in any layer.
Radim
> T
> Trevor Wiens
> The significant problems that we face cannot be solved at the same
> level of thinking we were at when we created them.
> (Albert Einstein)
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
