[GRASS5] Re: i.vpoints and the new gism
Michael Barton michael.barton at asu.edu
Mon Mar 13 15:09:43 EST 2006
Carlos,
You can open a monitor (using d.mon) from the command line, size it the way
you want, and start i.vpoints from the command line.
A short while ago, I suggested that a new module (i.gcp?) could be written
that would simply accept 2 xy pairs for input. It would add, delete,
activate, or deactivate a line with these point pairs in the (ascii) points
file and calculate rms error for activated points in the file.
Then a GUI could get the points by clicking with a mouse or let you enter
them manually, without reliance on a xmonitor or any other particular type
of display.
<ocjae;
On 3/13/06 8:58 AM, "Carlos "Guâno" Grohmann" <carlos.grohmann at gmail.com>
wrote:
> Hello Micheal,
> I just wrote a msg to Markus about i.vpoints (which is kinda broken,
> and Markus was trying to fix it, but apparently the code is written in
> a misterious way...).
> Before writin him, I tried i.vpoints with the last cvs and the new
> gism (BTW, nice job!). Here are some points I told him about the
> behaviour of i.vpoint and the new gism:
>> BTW, I just trid it with the last cvs using the new gism, and now
>> there is a problem about the monitors, since the new gism uses ppm
>> instead of the old monitors. When i.vpoints is called, it start  a
>> monitor, but you can't resize the window, because the command is
>> running. So I tried to sopt i.vpoints, resize the monitor and run it
>> again (as I would do with the 'old' gism), but it won't work, because
>> i.vpoints will open a new monitor (small, again)...
> Best regards
>               Carlos Henrique Grohmann - Guano
>   Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
> Linux User #89721  - carlos dot grohmann at gmail dot com
> _________________
> "Good morning, doctors. I have taken the liberty of removing Windows
> 95 from my hard drive."
> --The winning entry in a "What were HAL's first words" contest judged
> by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
___________________________
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287
WWW - http://www.public.asu.edu/~cmbarton
Phone: 480-965-6262
Fax: 480-965-7671
