[GRASS5] NVIZ and threaded TCL 8.4 working
Tue Mar 14 22:24:49 EST 2006
Cedric Shock wrote:
> My tcl and tk 8.4 binaries are Ubuntu, which are probably pretty similar to
> debian's.
> Many of the nviz c source files call Tcl_Merge to make return strings, and
> assign them to interp->result where interp is the TCL interpreter like this:
> interp->result = Tcl_Merge(3, list);
> Then they set the freeProc ("function" to call to free the memory) to be free
> (glibc). Tcl_Merge allocates its memory with Tcl_Alloc, not with malloc.
> Before 8.4 Tcl_Alloc just happened to be malloc, but it's not anymore. The
> correct thing to do is to set the freeProc to be TCL_DYNAMIC, which will be
> TCL's opposite of Tcl_Alloc, like this:
> interp->freeProc = TCL_DYNAMIC;
Will this also work in 8.3?
