[GRASS5] [bug #4186] (grass) grass61 command: all parameters specified or none of them
Request Tracker grass-bugs at intevation.de
Sat Mar 18 01:27:04 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4186
Subject: grass61 command: all parameters specified or none of them
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: 20060316
Documentation and help for the command grass61 specifies that:
You must specify one of the following
MAPSET
LOCATION_NAME/MAPSET
GISDBASE/LOCATION_NAME/MAPSET
In fact, at the commandline, only the last option works:
the other options are ambiguous and result in a "Not a valid Location" error.
-------------------------------------------- Managed by Request Tracker
