[GRASS5] [bug #4186] (grass) grass61 command: all parameters specified or none of them
Sat Mar 18 20:14:37 EST 2006
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4186
> Subject: grass61 command: all parameters specified or none of them
> Platform: GNU/Linux/x86
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: 20060316
> Documentation and help for the command grass61 specifies that:
> You must specify one of the following
> MAPSET
> LOCATION_NAME/MAPSET
> GISDBASE/LOCATION_NAME/MAPSET
> In fact, at the commandline, only the last option works:
> the other options are ambiguous and result in a "Not a valid Location"
> error.
This is uncorrect. It works fine but you have to be in the correct
directory.
e.g. these all work:
cd $MAPSET
grass61 `pwd`
# this works but mapset name in g.gisenv is ".", which is bad
cd $MAPSET
grass61 .
cd $LOCATION
grass61 $MAPSET
cd $GISDBASE
grass61 $LOCATION/$MAPSET
and finally
grass61 $GISDBASE/$LOCATION/$MAPSET
the trick is you have to be in the correct part of the file system.
e.g. if $MAPSET = $USER, grass61 $USER from /home could very well be
ambiguous.
This seems like a good time to again call for an enhancement to the
TclTk startup screen: double clicking on a mapset name should imply
"continue".
Hamish
