[GRASS5] Re: [GRASSLIST:205] Re: Sum for an area
Hamish
hamish_nospam at yahoo.com
Sat Mar 18 23:15:32 EST 2006
> >r.univar too; any thoughts from the list on if r.univar should report
> >sum in full instead of shortening to 1.23456e+07?
> To me a shortened value doesn't make much sense.
Ok, updated in CVS:
+ char sum_str[100];
+ sprintf(sum_str, "%.10f", sum);
+ G_trim_decimal(sum_str);
- fprintf(stdout, "sum: %g\n", sum);
+ fprintf(stdout, "sum: %s\n", sum_str);
G_trim_decimal() could be used elsewhere.. e.g. if you import easting
and northings in columns with v.in.ascii, then use the d.what.vect form
you get 0.000000 everywhere and %g will convert to +e06 fomat.
question:
will "%.15g" do the same job, just as well?
Hamish
