[GRASS5] New GRASS addons CVS repository?
Markus Neteler
neteler at itc.it
Mon Mar 20 07:54:09 EST 2006
On Mon, Mar 20, 2006 at 08:19:46AM -0400, Patton, Eric wrote:
> Hamish,
> This is a concern I had as well for people like myself who are starting to
> get their feet wet submitting new scripts to the add-ons section. The WIKI
> method is easy to contribute now, but I had a hell of a time trying to get
> cvs configured properly - and eventually gave up as it became an enormous
> time vaccuum. Probably attributable to user error, but certainly not what I
> would call 'easy'.
Eric,
would you mind to summarize the problems? Then we can check
how to simplify it if possible.
> Would this new, proposed method of submitting code require the use of
> CVS-compiled Grass in order to contribute?
It depends in any case: if the contribution uses a new
feature of GRASS-CVS, then even a Wiki contribution would need it.
> I hope not - I'm pretty loathe to
> start mucking around with installation now that I've finally got everything
> on Ubuntu running smoothly.
Please elaborate...
Markus
> ~ Eric.
> >The nice thing about the Wiki is the low barrier to entry to anyone.
> >Can submitters to the new repo be given rights to their own dir or do
> >they need general write permission on everything at Intevation's CVS?
> >Hamish
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
