[GRASS5] [bug #4190] (grass) Could not import a NB Double Ste
reographic shapefile - used EPSG #2036
Patton, Eric
epatton at nrcan.gc.ca
Tue Mar 21 06:28:13 EST 2006
Here's the output from ogrinfo on my shapefile:
ogrinfo 45256600_h_r.shp
INFO: Open of `45256600_h_r.shp'
using driver `ESRI Shapefile' successful.
1: 45256600_h_r (Polygon)
Hm, no projection info, coordinate system, nothing. But the prj is in the
same directory as the shapefile.
Maybe the problem lies in the shapefile and associated files (?)
~ Eric.
-----Original Message-----
To: Request Tracker
Cc: grass5 at grass.itc.it
Sent: 3/20/2006 8:29 PM
Subject: Re: [GRASS5] [bug #4190] (grass) Could not import a NB Double
Stereographic shapefile - used EPSG #2036
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4190
> Subject: Could not import a NB Double Stereographic shapefile - used
> EPSG #2036
> Platform: GNU/Linux/x86
> grass obtained from: Trento Italy site
> grass binary for platform: Downloaded precompiled Binaries
> GRASS Version: Grass 6.1cvs 18-03-2006
> I downloaded this shapefile:
> https://www.web11.snb.ca/topo/aadb/shape/nbaa_5000_ranb.zip
> The shapefile is in New Brunswick Double Stereographic, NAD83 CSRS98
> (Canadian Spatial Reference System 1998)
> This shapefile comes from a municipal government site, so is highly
> likely that the shapefile is in the projection is says it is. Or at
> least it's not suspect at this point.
> Reading the .prj file shows that the projection is indeed New
> Brunswick Double Stereographic. I created a new Location using EPSG
> code #2036, which seemed to match the shapefile's projection
> parameter-for-parameter. Imported shapefile into Location using:
> v.in.ogr dsn=shapefile_directory output=nbaa_5000_ranb
> layer=nbaa_5000_ranb
> and received a seg fault, with no other error information. Importing
> the shapefile using the 'location' parameter in v.in.ogr also gives a
> seg fault, with no feedback.
what happens if you try looking at it with 'ogrinfo' ?
also, maybe quicker for you, the above can just be:
v.in.ogr dsn=directory/file.shp out=map # and no layer=
Hamish
grass5 mailing list
http://grass.itc.it/mailman/listinfo/grass5
