[GRASS5] [bug #4190] (grass) Could not import a NB Double Ste reographic shapefile - used EPSG #2036
Markus Neteler neteler at itc.it
Tue Mar 21 06:52:08 EST 2006
Eric,
this also confused me - but it's the usage of ogrinfo
(I didnÃ't manage to convince Frank to change that, see our
recent GDAL-ML communication):
Try instead:
ogrinfo -so 45256600_h_r.shp 45256600_h_r
then you'll see the proj info.
Markus
On Tue, Mar 21, 2006 at 07:28:13AM -0400, Patton, Eric wrote:
> Here's the output from ogrinfo on my shapefile:
> ogrinfo 45256600_h_r.shp
> INFO: Open of `45256600_h_r.shp'
> using driver `ESRI Shapefile' successful.
> 1: 45256600_h_r (Polygon)
> Hm, no projection info, coordinate system, nothing. But the prj is in the
> same directory as the shapefile.
> Maybe the problem lies in the shapefile and associated files (?)
> ~ Eric.
> -----Original Message-----
> From: grass5-admin at grass.itc.it
> To: Request Tracker
> Cc: grass5 at grass.itc.it
> Sent: 3/20/2006 8:29 PM
> Subject: Re: [GRASS5] [bug #4190] (grass) Could not import a NB Double
> Stereographic shapefile - used EPSG #2036
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=4190
> > Subject: Could not import a NB Double Stereographic shapefile - used
> > EPSG #2036
> > Platform: GNU/Linux/x86
> > grass obtained from: Trento Italy site
> > grass binary for platform: Downloaded precompiled Binaries
> > GRASS Version: Grass 6.1cvs 18-03-2006
> > I downloaded this shapefile:
> > https://www.web11.snb.ca/topo/aadb/shape/nbaa_5000_ranb.zip
> > The shapefile is in New Brunswick Double Stereographic,  NAD83 CSRS98
> > (Canadian Spatial Reference System 1998)
> > This shapefile comes from a municipal government site, so is highly
> > likely that the shapefile is in the projection is says it is. Or at
> > least it's not suspect at this point.
> > Reading the .prj file shows that the projection is indeed New
> > Brunswick Double Stereographic. I created a new Location using EPSG
> > code #2036, which seemed to match the shapefile's projection
> > parameter-for-parameter. Imported shapefile into Location using:
> > v.in.ogr dsn=shapefile_directory output=nbaa_5000_ranb
> > layer=nbaa_5000_ranb
> > and received a seg fault, with no other error information. Importing
> > the shapefile using the 'location' parameter in v.in.ogr also gives a
> > seg fault, with no feedback.
> what happens if you try looking at it with 'ogrinfo' ?
> also, maybe quicker for you, the above can just be:
> v.in.ogr dsn=directory/file.shp out=map  # and no layer=
> Hamish
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
> grass5 mailing list
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
