[GRASS5] Re: [bug #4164] (grass) v.clean: uses 1GB RAM, 1 GB swap for a vector with only 628 boundaries
Radim Blazek
radim.blazek at gmail.com
Thu Mar 23 02:43:36 EST 2006
On 3/22/06, Maciek Sieczka <werchowyna at epf.pl> wrote:
> Now, not using "debug=clean": the v.buffer creates _mostly_ good result
> when compared to r.buffer at resolution =1. But there are at least 2
> places with errors visible in v.buffer behaviour. Please see the
> attached screendump, you will spot them easily.
> The YELLOW lines are the v.buffer and r.buffer input.
> The RED backgroung is r.buffer output (GOOD).
> The BLACK lines are v.buffer output, with at least 2 ERRORS visible,
> indicated by GREEN circles.
> Are those possible to be fixed Radim?
Not now by me. If possible publish your input data so that it can
be used for debugging in future.
How do look those 2 places if run with debug=clean?
Radim
> Maciek
> W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
> http://katalog.panoramainternetu.pl/
