[GRASS5] gis.m output change, default tk gui configuration options
Markus Neteler
neteler at itc.it
Fri Mar 24 02:51:51 EST 2006
Cedric Shock wrote:
>Hello,
>Aside: I'll be away from computers for a week starting Friday afternoon :)
>I have committed a couple medium-sized user interface changes to CVS. gis.m
>now has a different run and output interface. The beginning skeleton of an
>options system is being made.
>I have committed changes to gis.m so that it uses the shared run and output
>code for output. I also changed around the run user interface a bit. Commands
>run from the menus in gis.m will have their output displayed in the output
>window.
>gui.tcl now sources /lib/gtcltk/options.tcl which is installed in
>$GISBASE/etc/gtcltk/. This file sets up color and font options as well as a
>couple miscellaneous global variables. It uses the tk options database. This
>database allows rules to be specified for tk widget options based on the name
>of the option (ex: font), the name of the widget (ex:. .titlelabel), the
>class of the widget (ex: Button), and a few others. These options are applied
>to every widget created after the option is set unless it is overridden by
>the command that creates the widget or a subsequent configure command. This
>leads to a few good programming practices for tcl/tk programmers:
>1. Don't set options like -foreground or -background or -font when creating
>widgets, unless theres a really _really_ specific reason to have it that
>color (like it's demonstrating that color).
>2. If you want something like a label to look different than everything else
>of that class (other labels) give it a distinctive name,
>like .moduletitlelabel . If you have a bunch of them give them all the same
>distinctive name. This allows them to have their options controlled by the
>options database. If this isn't good enough then we'll write a proc for
>handling special classes.
>We can make options.tcl look for options files per mapset or user and load
>them after setting the defaults. Eventually we could write a module for
>changing these (after adding color and font selection to gisprompt somehow).
Cedric, all,
thanks for all your work on the GUI!
What about creating a new file SUBMITTING_TCLTK which gets populated
which such good practice hints as seen above?
We already have SUBMITTING (basically for C) and SUBMITTING_SCRIPTS (shell).
In the ML archive it will get sort of lost.
Markus
