[GRASS5] Re: [GRASSLIST:373] v.in.dxf
Radim Blazek
radim.blazek at gmail.com
Tue Mar 28 02:28:58 EST 2006
On 3/27/06, Huidae Cho <grass4u at gmail.com> wrote:
> Done in CVS except for layer selection.
Thanks.
> BTW, why does "d.vect layer=" display
> ALL layers? I had to add cats=1-9999999 to see what's in a given layer. Is this
> a feature?
> d.vect map=mymap layer=4 # is the same as d.vect map=mymap
> d.vect map=mymap layer=4 cats=1-99999999 # displays the layer 4
Yes, layer=4 should only display the layer 4. I think that evolution was
d.vect
d.vect cats=
d.vect cats= layer=
but d.vect layer= was not implemented.
Radim
> Huidae Cho
