[GRASS5] Re: [GRASSLIST:373] v.in.dxf
Paolo Cavallini cavallini at faunalia.it
Thu Mar 30 11:19:17 EST 2006
Is that correct that v.in.dxf works with version R12 only?
We tested with R14 and 2000, and got no results.
pc
At 21:31, lunedì 27 marzo 2006, Huidae Cho has probably written:
> Done in CVS except for layer selection. BTW, why does "d.vect layer="
> display ALL layers? I had to add cats=1-9999999 to see what's in a given
> layer. Is this a feature?
> d.vect map=mymap layer=4		 # is the same as d.vect map=mymap
> d.vect map=mymap layer=4 cats=1-99999999 # displays the layer 4
> Huidae Cho
Paolo Cavallini
email+jabber: cavallini at faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy   Tel: (+39)348-3801953
