[GRASS5] Re: [GRASSLIST:373] v.in.dxf
Huidae Cho grass4u at gmail.com
Thu Mar 30 12:53:43 EST 2006
v.in.dxf was originally written in 1989, so there is a great chance that it
will not work with a newer version of DXF.  If you don't mind, could you please
give me DXFs that you tried so that I can take a look at the format?
Huidae Cho
On Thu, Mar 30, 2006 at 06:19:17PM +0200, Paolo Cavallini wrote:
> Is that correct that v.in.dxf works with version R12 only?
> We tested with R14 and 2000, and got no results.
> pc
> At 21:31, lunedì 27 marzo 2006, Huidae Cho has probably written:
> > Done in CVS except for layer selection. BTW, why does "d.vect layer="
> > display ALL layers? I had to add cats=1-9999999 to see what's in a given
> > layer. Is this a feature?
> > d.vect map=mymap layer=4		 # is the same as d.vect map=mymap
> > d.vect map=mymap layer=4 cats=1-99999999 # displays the layer 4
> > Huidae Cho
> Paolo Cavallini
> email+jabber: cavallini at faunalia.it
> www.faunalia.it
> Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy   Tel: (+39)348-3801953
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
