[GRASS5] Re: [GRASSLIST:373] v.in.dxf
Thu Mar 30 22:10:53 EST 2006
> Is that correct that v.in.dxf works with version R12 only?
No. I don't know if it will work with anthing newer than R10.
Do you have it working with a R12 file?
> We tested with R14 and 2000, and got no results.
You will need v.in.dwg for those.
see  http://grass.itc.it/pipermail/grassuser/2006-March/033407.html
     https://intevation.de/rt/webrt?serial_num=2451
Hamish
