[GRASS5] Re: [GRASSLIST:373] v.in.dxf
Paolo Cavallini
cavallini at faunalia.it
Fri Mar 31 00:56:22 EST 2006
At 05:10, venerdì 31 marzo 2006 you presumably wrote:
> > Is that correct that v.in.dxf works with version R12 only?
> No. I don't know if it will work with anthing newer than R10.
> Do you have it working with a R12 file?
I confirm: it is working with R12 (still have to check whether anything is
missing, but it seems OK).
> > We tested with R14 and 2000, and got no results.
> You will need v.in.dwg for those.
Wouldn't it be feasible to upgrade v.in.dxf? Perhaps borrowing some code from
other software, like qcad?
> see http://grass.itc.it/pipermail/grassuser/2006-March/033407.html
> https://intevation.de/rt/webrt?serial_num=2451
> Hamish
Paolo Cavallini
email+jabber: cavallini at faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
