[GRASS5] Re: [GRASSLIST:373] v.in.dxf
Hamish
hamish_nospam at yahoo.com
Fri Mar 31 18:18:28 EST 2006
> > > We tested with R14 and 2000, and got no results.
> > You will need v.in.dwg for those.
> Wouldn't it be feasible to upgrade v.in.dxf? Perhaps borrowing some
> code from other software, like qcad?
I see that qcad claims to open dxf 2004, via "dxflib", which is GPL.
http://www.ribbonsoft.com/dxflib.html
Can you open your 2004 files in QCAD cleanly? resave from there in a
compatible format?
> > see http://grass.itc.it/pipermail/grassuser/2006-March/033407.html
> > https://intevation.de/rt/webrt?serial_num=2451
Hamish
