[GRASS5] set map title and metadata info using r.support
Huidae Cho
grass4u at gmail.com
Wed Mar 29 04:13:11 EST 2006
On Tue, Mar 28, 2006 at 06:30:59PM +1200, Hamish wrote:
> > > I've added two options to r.support to let you change the map's
> > > title and add a line of metadata info to the map's hist/ file
> > > (viewable with r.info, r.info -h). They will both run
> > > non-interactively from the command line.
> > Given that r.support has historically been an interactive module, it
> > might be better to put this functionality into separate modules (which
> > was the approach I took with r.region).
> It didn't seem like it was worth the overhead for a couple lines of
> code. If anything I considered merging r.timestamp into r.support. As
> this wasn't a scriptable module the two new options shouldn't change any
> historic use of r.support at all, just add something more and help us
> on our way to getting rid of some more G_ask() calls. I agree that
> r.region is best on its own.
> > > I am looking for a simple bashism to add to the examples section of
> > > the help page for feeding an input file one line at a time into the
> > > (looped) module.
> > while read line ; do
> > r.support map="$map" history="$line"
> > done < "$file"
> Yep, thanks. It occured to me this morning that I should use "read", it
> works.
> While on "read", another question: For a while I've wanted to have a
> port of m.proj2 in GRASS 6, but as a script calling cs2cs. Especially
> the -i and -o options to convert a list of coordinates from WGS84
> lat/lon into the current projection and convert grid coords to WGS84 LL.
> It's pretty easy:
> IN_PROJ="+proj=longlat +towgs84=0.000,0.000,0.000"
> OUT_PROJ="`g.proj -jf`"
> cs2cs -f %.8f $IN_PROJ +to $OUT_PROJ < "${TMP}.in" > "${TMP}.out"
> Right now I just do this by hand, but it would be great to be able to
> reduce the above to "m.proj -i" plus redirection.
> What I haven't been able to figure out is how to have a bash script
> optionally accept input piped from stdin. My attempts using read have
> been unsatisfactory. This should work the same way as both v.in.ascii
> and v.out.ascii. Both input= and output= options are optional filenames or
> if omitted assumed to be stdin, stdout.
You may want to try this:
#!/bin/sh
if [ "$1" != "" ]
then
exec 0<"$1"
fi
while read line
do
echo $line
done
The first parameter is an optional filename.
Huidae Cho
> e.g.
> G> v.out.ascii $map | tr '|' ' ' | m.proj -o > map_LL.txt
> m.proj [-iod] [input=name] [output=name] [inproj=string] [outproj=string]
> Flags:
> -i Use WGS84 as input and current location as output projection
> -o Use current location as input and WGS84 as output projection
> -d Output lat/long in decimal degrees
> Parameters:
> input Input coordinate file
> output Output coordinate file
> inproj input projection parameters
> outproj output projection parameters
> The name of such a module is also open for suggestions.
> thanks,
> Hamish
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
