[GRASS5] problem with v.vol.rst
Jaro Hofierka
hofierka at geomodel.sk
Thu Mar 30 02:17:05 EST 2006
Istvan,
The module uses a segmantation procedure for datasets with more ~600
points. If the number is less then you can interpolate without
segmentation (i.e. "segmax=600" option should be added to the command I
believe). Otherwise you must use higher npmin to include more points for
interpolation within the segment.
Hope this helps.
Jaro
Stefán István wrote:
> Hello List,
> I've been routed from the general Grass list to here with my problem.
> I have a problem with v.vol.rst module:
> If I set the tension parameter to high value (over 40) then after I make
> slices from the volume, the resulted 2d raster maps will contain squares.
> The author of the r3.to.rast module says that it could be a problem of the
> interpolation module. In the attached jpeg you can see what I mean under
> "squared".
> Thank you for your help,
> Istvan
> __________ Informacia od NOD32 1.1458 (20060324) __________
> Tato sprava bola preverena antivirusovym systemom NOD32.
> http://www.eset.sk
________ Information from NOD32 ________
This message was checked by NOD32 Antivirus System for Linux Mail Server.
http://www.nod32.com
