[GRASS5] Re: [GRASSLIST:496] Re: GRASS test suite
Sören Gebbert soerengebbert at gmx.de
Fri Mar 31 03:54:20 EST 2006
Hi Radim,
On Friday 31 March 2006 10:31, Radim Blazek wrote:
> Good,
> could you please run it also on Windows version?
> http://mpa.itc.it/radim/wingrass/qgis-0.8.0-preview-win32-060329.zip
> The package includes MSYS and shell so it should be possible
> to run your test. You can either start it from script setting GISRC
> or you can start QGIS, open a mapset and then start GRASS shell
> from GRASS tools.
> Radim
I will try, but i think this wont work. I'm using some Unix tools like sed,  rm and stuff.
I will see if MSYS provides those tools, because i didnt find much information about this toolset
at http://www.mingw.org/msys.shtml ... . I think this is only a bash and tar????
I tried first to use only bash functionality, but this functionality is to limited
for the test suite. So i had to use Unix tools too.
Also md5sum must be installed in windows,
otherwise the md5 checksum tests are not available.
Is there no other bash-unix-tool environment for windows available?
I didnt found one.
And how about the existing shell scripts in grass,
do they work with MSYS and GRASS with windows?
I will try this out this evening.
Best regards
Soeren
> On 3/30/06, Sören Gebbert <soerengebbert at gmx.de> wrote:
> > Hi all,
> > since some weeks i'm developing a test suite for GRASS.
> > I have implemented a test frame work and some basic tests.
> > I would like to have some feedback from the devs and users if the concept
> > of the test suite is correct or even meaningful, because i'm thinking a test suite is very important
> > for GRASS, especially for the development process.
> > I hope to provide an environment for easy test development to support
> > stability and error reduction for GRASS.
> > You can download the latest test suite and the test location here:
> > http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/GRASS_Testsuite.tar.gz
> > http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/spearfish_grass60data.tar.gz
> > The test suite will only work correctly within the test location (this is the newest
> > not modified spearfish60 location) and with a fresh grass-6.1 cvs version!
> > If you run the test suite, you can compare your results with my results:
> > http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/html/GRASSSummary.html
> > I made a (currently incomplete) video tutorial in german and a pdf presentation in english and german.
> > Because i'm not a nativ english speaker, i would encourage the native's to check the
> > english presentation. It would be a great help for me, if you can support me to write better
> > presentations and tutorials.
> > The video tutorials and the pdf presentations are available here:
> > http://www-pool.math.tu-berlin.de/~soeren/grass/modules/
> > The video tutorial is splitted into two parts. The first part is completely in
> > german and shows only the presentation, which are also available
> > in english and german as pdf and OpenOffice2 format.
> > The second part of the video tutorial shows the handling of the test suite and ist partly in german (the small text parts).
> > Those small text parts are also available in the english pdf presentation.
> > So if you read the english pdf presentation, you can easily follow the second part of the tutorial.
> > English presentation:
> > http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/GRASS-Testsuite-Presentation-OO2-New_en.pdf
> > Part two of the tutorial:
> > http://www-pool.math.tu-berlin.de/~soeren/grass/modules/Tutorials/Testsuite/Testsuite_Tutorial_part2_de.html
> > I wish to add an english tutorial too, but have no time for that for the next months.
> > Thank you in advance for your
> > comments, suggestions or constructive criticism.
> > Everything is welcome!!
> > Best regards
> > Soeren
