[GRASS5] [bug #4356] (grass) d.m: d.rast.num fails when called
from 'Add comand layer'
Hamish
hamish_nospam at yahoo.com
Tue May 2 02:47:05 EDT 2006
> > I notice rendering is fairly quick off screen, quite slow on screen.
> > (e.g fliping to a different workspace speeds it up 100x)
> > For me calling from gis.m seems to be 100x slow...
> d.rast.num call R_flush() once per character. Ouch.
removed in CVS, thanks. Much faster now.
> For the PNG driver, that call causes the image to be written out if it
> has been modified (which, in this case, it will be; one more character
> has been drawn).
> For the X driver, it "clears" the window (i.e. fills it with the
> background pixmap, onto which everything is drawn). I suspect that the
> X server may defer the filling operation if the window isn't visible.
> Fix: remove the R_flush() call from the bottom of draw_number(); it's
> completely gratuitous.
> Modules should only call that function once a sequence of drawing
> operations have completed and no further operations will occur for an
> indefinite period (e.g. until the user interacts via the mouse or
> terminal).
> Actually, any use of that call in a d.* module is either gratuitous,
> or indicates an interactive module which need to be changed or
> replaced as part of the GUI project.
[display]$ grep -rI R_flush *
d.colors/get_info.c: R_flush() ;
d.colors/interact.c: R_flush() ;
d.geodesic/plot.c: R_flush();
d.histogram/main.c: R_flush();
d.linegraph/linegraph.c: R_flush ();
d.path/select.c: R_flush();
d.profile/What.c: R_flush();
d.rast/display.c: R_flush() ;
d.rhumbline/plot.c: R_flush();
d.text.freetype/main.c: R_flush();
d.what.vect/flash.c: R_flush();
Hamish
