[GRASS5] [bug #4356] (grass) d.m: d.rast.num fails when called
from 'Add comand layer'
Glynn Clements
glynn at gclements.plus.com
Tue May 2 13:31:49 EDT 2006
Hamish wrote:
> > Actually, any use of that call in a d.* module is either gratuitous,
> > or indicates an interactive module which need to be changed or
> > replaced as part of the GUI project.
> [display]$ grep -rI R_flush *
> d.colors/get_info.c: R_flush() ;
> d.colors/interact.c: R_flush() ;
> d.geodesic/plot.c: R_flush();
> d.histogram/main.c: R_flush();
> d.linegraph/linegraph.c: R_flush ();
> d.path/select.c: R_flush();
> d.profile/What.c: R_flush();
> d.rast/display.c: R_flush() ;
> d.rhumbline/plot.c: R_flush();
> d.text.freetype/main.c: R_flush();
> d.what.vect/flash.c: R_flush();
Those are all either interactive, or only call R_flush() just before
termination (unnecessary, but harmless), or R_flush() is commented
out or controlled by a macro (e.g. d.text.freetpe only calls it if
FLUSH_EACH_CHAR is defined, which is presumably a debugging feature).
