[GRASS5] 100% cpu mouse bug
Radim Blazek radim.blazek at gmail.com
Tue May 2 09:26:12 EDT 2006
On 4/26/06, Radim Blazek <radim.blazek at gmail.com> wrote:
> Yes, I fixed first the modules which dont need to update TclTk GUI
> (d.zoom, d.what.rast,d.what.vect -x) and I thought that I fixed
> also the v.digit and d.what.vect. Now I see that there is still problem with
> the form. Note however that R_get_location_* are fixed and the only problem
> is in form.
I added select() also to the form, everything (d.what.vect, v.digit)
should be now fixed.
Radim
