[GRASS5] 100% cpu mouse bug
Hamish
hamish_nospam at yahoo.com
Wed May 3 02:21:33 EDT 2006
> > Yes, I fixed first the modules which dont need to update TclTk GUI
> > (d.zoom, d.what.rast,d.what.vect -x) and I thought that I fixed
> > also the v.digit and d.what.vect. Now I see that there is still
> > problem with the form. Note however that R_get_location_* are fixed
> > and the only problem is in form.
> I added select() also to the form, everything (d.what.vect, v.digit)
> should be now fixed.
d.what.vect (with an without -e) is fixed for me. Great.
v.digit still goes to 100% when I open the settings page or deselect a
tool with the right mouse button.
Almost there... once done & well tested should this be backported to
the 6.0.x line or are the changes too invasive?
Hamish
