[GRASS-dev] Re: [GRASS5] 100% cpu mouse bug
Radim Blazek
radim.blazek at gmail.com
Fri May 5 04:38:13 EDT 2006
On 5/3/06, Hamish <hamish_nospam at yahoo.com> wrote:
> > > Yes, I fixed first the modules which dont need to update TclTk GUI
> > > (d.zoom, d.what.rast,d.what.vect -x) and I thought that I fixed
> > > also the v.digit and d.what.vect. Now I see that there is still
> > > problem with the form. Note however that R_get_location_* are fixed
> > > and the only problem is in form.
> > I added select() also to the form, everything (d.what.vect, v.digit)
> > should be now fixed.
> d.what.vect (with an without -e) is fixed for me. Great.
> v.digit still goes to 100% when I open the settings page or deselect a
> tool with the right mouse button.
I added nanosleep for TOOL_NOTHING if available.
Radim
> Almost there... once done & well tested should this be backported to
> the 6.0.x line or are the changes too invasive?
> Hamish
