[GRASS5] Improvements to gis.m map canvas
Cedric Shock cedricgrass at shockfamily.net
Wed May 3 00:11:48 EDT 2006
I made a couple fairly big improvements to gis.m. The redrawing of mapcanvases
is now regulated by a little server that waits for requests and redraws
whenever there's a request. This keeps the redraws down to one at a time.
This makes resizing the canvas and zooming work more smoothly.
A procedure that wants the canvas redrawn should now do
MapCanvas::request_redraw $mon 1
if the procedure changed the canvas or the view and
MapCanvas::request_redraw $mon 0
if the view and canvas are unchanged.
I removed a few unnecessary "source"s and "after"s. gis.m starts 4-5 seconds
faster on my computer now. That's about half the time spent between when
gm.tcl starts running and when it reaches the end. The biggest chunks of
startup time now are wish starting, disk access to source the files, and
running the procedures and parts of sourced files that actually do something
on startup. Sourcing all the code that does nothing seems to have virtually
zero cost beyond disk access. This shouldn't be surprising since the procs
aren't compiled until their first use.
There is still one "after" in MapCanvas::mapsettings after running "d.mon
stop=gism" to "wait to make sure that the driver is shut down". This is
probably extraneous, but I'm not sure since the R_ commands seem to just push
messages off to another process. If it's not needed we can shave a nice
big .5 seconds off many redraws.
--Cedric
