[GRASS5] Improvements to gis.m map canvas
Glynn Clements
glynn at gclements.plus.com
Wed May 3 00:46:26 EDT 2006
Cedric Shock wrote:
> There is still one "after" in MapCanvas::mapsettings after running "d.mon
> stop=gism" to "wait to make sure that the driver is shut down". This is
> probably extraneous, but I'm not sure since the R_ commands seem to just push
> messages off to another process. If it's not needed we can shave a nice
> big .5 seconds off many redraws.
It shouldn't be necessary; I changed R_kill_driver() so that it
doesn't return until the driver has actually terminated.
Also, it should only be necessary to restart the driver if the image
dimensions are changed; changing the region shouldn't require a
restart.
