[GRASS5] NVIZ image dump broken?
Wed May 3 02:34:53 EDT 2006
> the NVIZ image dump to TIFF no longer works for me.
> The result image is replicated inside the output
> file and basically useless.
It works fine for me.
I seem to remember this same problem was reported to the mailing list
just a few days/week ago. You are using 64bit, correct? I've got a
feeling that previous report was 64bit too.
The htdig search engine is broken currently (even a search for "grass"
gives 0 hits), and I can't connect to Gmane - so sorry no link.
Did it work with yesterday's CVS? (lib/ogsf/gs_bm.c change)
> If I recall correctly, someone modified this recently
> (Hamish?).
Mine was just to change a G_fatal_error() to G_warning(), and to guard
against unwanted ".tif.tif" output file extensions. Nothing to do with
rendering (you'll have to ask Bob about that).
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/lib/ogsf/gsd_img_tif.c
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/lib/ogsf/?sortby=date#dirlist
Hamish
