[GRASS5] Re: [GRASS] WMS -> CVS
Hamish
hamish_nospam at yahoo.com
Wed May 3 03:01:54 EDT 2006
> I committed the big collection of r.in.wms scripts to CVS. Three of
> them are visible publically: r.tileset, r.in.wms,
"r.in.wms -l" doesn't work for me.
using the example onearth server on the man page I see wget run, but
then no output and just a prompt. Using terraserver,
G61> r.in.wms mapserver=http://terraserver.microsoft.com/ogcmap6.ashx -l
[...]/16132.0capabilities.xml' saved [421]
error: Opening and ending tag mismatch: br and body
error: Opening and ending tag mismatch: br and html
error: Extra content at the end of the document
G61>
commenting out the rm tempfile line I see the problems:
G61> r.in.wms mapserver=http://wms.jpl.nasa.gov/wms.cgi -l
$ cat 16193.0capabilities.xml
<?xml version='1.0' encoding="UTF-8" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://www.digitalearth.gov/wmt/xml/exception_1_1_0.dtd ">
<ServiceExceptionReport version="1.1.0">
<ServiceException>
Service denied due to system overload. Please try again later.
</ServiceException>
</ServiceExceptionReport>
$ cat 16210.0capabilities.xml
<html><head><title>OGCMap Test</title></head>
<body>
<h3>Service Exception Report</h3>
<p>Found 5 errors</p>
<br>Invalid Request 'GetCapabilities' - Value 'GetMap' is required
<br>BBOX (bounding box) parameter is missing.
<br>Layers parameter is missing.
<br>Width parameter is missing or is an invalid integer digit string.
<br>Height parameter is missing or is an invalid integer digit string.
</body></html>
Other issues:
I am not a fan of leaving the raw downloads in $GISDBASE.
Perhaps put in $MAPSET/.tmp/$HOST/... ?
i.e. I'd prefer a flag to KEEP the raw download, not to delete it.
I too am a big fan of r.in.onearth's simplicity, even if it is
somewhat redundant. Cedric's version doesn't replicate r.in.wms, it acts
as a frontend to it.
Wish:
g.tempfile needs a -d switch to create+return a dir in
$MAPSET/.tmp/$HOST/ instead of the user creating a file +tricks to use
that name as a tmp dir.
thanks,
Hamish
