[GRASS5] v.digit still segfaults
Wolf Bergenheim wolf+grass at bergenheim.net
Thu May 4 01:38:21 EDT 2006
Yes, and all it does is open a new monitor.
I also get the following error:
child process exited abnormally
     while executing
"exec -- d.mon start=x1 >& /dev/null"
     ("eval" body line 1)
     invoked from within
"eval exec -- $cmd $args >& /dev/null"
     (procedure "run" line 6)
     invoked from within
"run d.mon start=x1"
     invoked from within
"eval run $cmd $args"
     (procedure "runcmd" line 6)
     invoked from within
"runcmd "d.mon start=x$xmon""
     invoked from within
"if ![catch {open "|d.mon -L" r} input] {
 			while {[gets $input line] >= 0} {
             	if {[regexp -nocase "$xmon.*not running" $line]} {
 					run..."
     (procedure "Gm::xmon" line 10)
     invoked from within
"Gm::xmon run v.digit "
     invoked from within
".#menubar.#menubar#menu3.#menubar#menu3#menu1 invoke active"
     ("uplevel" body line 1)
     invoked from within
"uplevel #0 [list $w invoke active]"
     (procedure "tk::MenuInvoke" line 50)
     invoked from within
"tk::MenuInvoke .#menubar.#menubar#menu3.#menubar#menu3#menu1 1"
     (command bound to event)
--Wolf
On Wed, 3 May 2006, Michael Barton wrote:
> Did you do the following:
> open a display manually (d.mon start=x0)
> run v.digit
> The reason I ask is that there was a problem that I fixed today that
> involved automatically opening an x11 display for v.digit when the digitize
> button in gis.m is pushed. But this does NOT fix any problem in v.digit
> itself.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics and Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>> From: Wolf Bergenheim <wolf+grass at bergenheim.net>
>> Date: Thu, 4 May 2006 00:09:49 +0300 (EEST)
>> To: Michael Barton <michael.barton at asu.edu>
>> Cc: Wolf Bergenheim <wolf+grass at bergenheim.net>, GRASS developers
>> <grass5 at grass.itc.it>
>> Subject: Re: [GRASS5] v.digit still segfaults
>>> How did you run v.digit? From the GIS Manager, from the command line, both?
>> Both, I even tried it with the old d.m, but the most I got was either x0
>> (or x1) display opened or then a tcl prompt for v.digit parameters.
>> --Wolf
>>> Michael
>>> phone: 480-965-6213
>>> fax: 480-965-7671
>>>> Date: Wed, 3 May 2006 19:07:02 +0300 (EEST)
>>>> To: GRASS developers <grass5 at grass.itc.it>
>>>> Subject: [GRASS5] v.digit still segfaults
>>>> Hi,
>>>> I just did a fresh cvs checkout and rebuilt grass from scratch. v.digit
>>>> still segfaults :(
>>>> --Wolf
>>>> <:3 )---- Wolf Bergenheim ----( 8:>
>>> grass5 mailing list
>>> http://grass.itc.it/mailman/listinfo/grass5
