[GRASS5] v.digit still segfaults
Michael Barton michael.barton at asu.edu
Thu May 4 01:48:04 EDT 2006
Wolf,
Would you try simply running it from the command line.
D.mon x0
V.digit myexistingmap
(where myexistingmap is a vector map you already have), then try
D.mon x0
V.digit -n mynewmap
(where mynewmap is the name of a vector map that *doesn't* exist)
Thanks
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Wolf Bergenheim <wolf+grass at bergenheim.net>
> Date: Thu, 4 May 2006 08:38:21 +0300 (EEST)
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Wolf Bergenheim <wolf+grass at bergenheim.net>, GRASS developers
> <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] v.digit still segfaults
> Yes, and all it does is open a new monitor.
> I also get the following error:
> child process exited abnormally
>      while executing
> "exec -- d.mon start=x1 >& /dev/null"
>      ("eval" body line 1)
>      invoked from within
> "eval exec -- $cmd $args >& /dev/null"
>      (procedure "run" line 6)
>      invoked from within
> "run d.mon start=x1"
>      invoked from within
> "eval run $cmd $args"
>      (procedure "runcmd" line 6)
>      invoked from within
> "runcmd "d.mon start=x$xmon""
>      invoked from within
> "if ![catch {open "|d.mon -L" r} input] {
> while {[gets $input line] >= 0} {
> if {[regexp -nocase "$xmon.*not running" $line]} {
> run..."
>      (procedure "Gm::xmon" line 10)
>      invoked from within
> "Gm::xmon run v.digit "
>      invoked from within
> ".#menubar.#menubar#menu3.#menubar#menu3#menu1 invoke active"
>      ("uplevel" body line 1)
>      invoked from within
> "uplevel #0 [list $w invoke active]"
>      (procedure "tk::MenuInvoke" line 50)
>      invoked from within
> "tk::MenuInvoke .#menubar.#menubar#menu3.#menubar#menu3#menu1 1"
>      (command bound to event)
> --Wolf
> On Wed, 3 May 2006, Michael Barton wrote:
>> Did you do the following:
>> open a display manually (d.mon start=x0)
>> run v.digit
>> The reason I ask is that there was a problem that I fixed today that
>> involved automatically opening an x11 display for v.digit when the digitize
>> button in gis.m is pushed. But this does NOT fix any problem in v.digit
>> itself.
>> Michael
>> Center for Social Dynamics and Complexity
>> phone: 480-965-6213
>> fax: 480-965-7671
>>> Date: Thu, 4 May 2006 00:09:49 +0300 (EEST)
>>>> How did you run v.digit? From the GIS Manager, from the command line, both?
>>> Both, I even tried it with the old d.m, but the most I got was either x0
>>> (or x1) display opened or then a tcl prompt for v.digit parameters.
>>> --Wolf
>>>> Michael
>>>> phone: 480-965-6213
>>>> fax: 480-965-7671
>>>>> Date: Wed, 3 May 2006 19:07:02 +0300 (EEST)
>>>>> To: GRASS developers <grass5 at grass.itc.it>
>>>>> Subject: [GRASS5] v.digit still segfaults
>>>>> Hi,
>>>>> I just did a fresh cvs checkout and rebuilt grass from scratch. v.digit
>>>>> still segfaults :(
>>>>> --Wolf
>>>>> <:3 )---- Wolf Bergenheim ----( 8:>
>>>> _______________________________________________
>>>> grass5 mailing list
>>>> http://grass.itc.it/mailman/listinfo/grass5
