[GRASS5] Improvements to gis.m map canvas
Maciek Sieczka
werchowyna at epf.pl
Thu May 4 03:39:53 EDT 2006
On Wed, 03 May 2006 14:57:44 -0700
Michael Barton <michael.barton at asu.edu> wrote:
> These are both required unfortunately. If d.font romans is not done,
> GRASS won't display text properly. d.frame -e is needed to clear the
> display properly so that you can properly composite multiple layers.
<snip>
I see.
You haven't touched the second thing I mentioned though:
>> 2. when panning/zooming the are always two in a row "d.frame -e"
>> calls; necessary?
See the attached screendump. There are 2 "d.frame -e" in a row. Do we
need both?
To reproduce the behavior, please do the following:
1. run grass
2. add a layer in gis.m
3. redraw - in "Output - gis.m" window there are 2 "d.frame -e" calls
one after each other
Each subsequent redraw will result in a single "d.frame -e". When you
zoom or pan, there will be 2 of them again. Do we need them both?
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060504/73e23d5f/d.frame_x2.png
