[GRASS5] v.digit still segfaults
Jachym Cepicky jachym.cepicky at centrum.cz
Thu May 4 04:41:24 EDT 2006
Hallo and sorry - debuging is not my cup of tea, alas.
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1240430368 (LWP 6305)]
0xb7732203 in strlen () from /lib/tls/libc.so.6
(gdb) bt
#0  0xb7732203 in strlen () from /lib/tls/libc.so.6
#1  0xb7840789 in Tcl_ExternalToUtfDString () from /usr/lib/libtcl8.4.so.0
#2  0xb7905365 in Tk_MainEx () from /usr/lib/libtk8.4.so.0
#3  0x08052357 in main (argc=32, argv=0xbf84c134) at main.c:197
debian testing
Jachym
On Wed, May 03, 2006 at 10:23:59PM +0200, Markus Neteler wrote:
> On Wed, May 03, 2006 at 10:10:11PM +0200, Jachym Cepicky wrote:
> > Hallo,
> > confirm, v.digit segfaults:
> > GRASS 6.1.cvs:~ > v.digit -n pokus2
> > New empty map created.
> > Neoprávn?ný p?ístup do pam?ti (SIGSEGV)
> > GRASS 6.1.cvs:~ >
> > (gdb) run
> > Starting program: /usr/local/grass-6.1.cvs/bin/v.digit -n pokus3
> > [Thread debugging using libthread_db enabled]
> > [New Thread -1240200992 (LWP 6824)]
> > warning: Lowest section in /usr/lib/libicudata.so.34 is .hash at
> > 00000094
> > [New Thread -1240421456 (LWP 6828)]
> > [Switching to Thread -1240200992 (LWP 6824)]
> > 0xb776a203 in strlen () from /lib/tls/libc.so.6
> > (gdb)
> Hi Jachym
> an dieser Stelle muesstest Du
> bt
> eingeben, sonst weiss man nicht, wo es passiert.
> Debian?
> ciao
>  Markus
> > GRASS 6.1.cvs:~ > v.digit -n pokus4
> > D1/5: Map opened
> > D2/5: cat_init()
> > D2/5: symb_line_init()
> > D2/5: symb_node_init()
> > D5/5: driver_open()
> > D5/5:  -> opened
> > D2/5: top = 0 bot = 480, left = 0 right = 640
> > D2/5: n = 0.000000 s = 480.000000, w = 0.000000 e = 639.000000
> > D2/5: n = 4927970.730460 s = 4915893.960560, w = 593020.769477 e =
> > 609097.969406
> > D2/5: Scale = 25.159937
> > D5/5: driver_close()
> > D5/5:  -> closed
> > D5/5: driver_open()
> > D5/5:  -> opened
> > 609097.969406
> > D2/5: display_bg()
> > D5/5:  -> closed
> > D5/5: driver_open()
> > D5/5:  -> opened
> > 609097.969406
> > D2/5: display_map()
> > D2/5: set color to symb 2: 255 255 0
> > D2/5: set color to symb 13: 0 153 0
> > D2/5: set color to symb 12: 255 0 0
> > D5/5:  -> closed
> > Segmentation fault
> > GRASS 6.1.cvs:~ >
> > I hope, this helps.
> > Jachym
> > On Wed, May 03, 2006 at 12:59:23PM -0700, Michael Barton wrote:
> > > How did you run v.digit? From the GIS Manager, from the command line, both?
> > > Michael
> > > __________________________________________
> > > Michael Barton, Professor of Anthropology
> > > School of Human Evolution & Social Change
> > > Center for Social Dynamics and Complexity
> > > Arizona State University
> > > phone: 480-965-6213
> > > fax: 480-965-7671
> > > www: http://www.public.asu.edu/~cmbarton
> > > > From: Wolf Bergenheim <wolf+grass at bergenheim.net>
> > > > Date: Wed, 3 May 2006 19:07:02 +0300 (EEST)
> > > > To: GRASS developers <grass5 at grass.itc.it>
> > > > Subject: [GRASS5] v.digit still segfaults
> > > > Hi,
> > > > I just did a fresh cvs checkout and rebuilt grass from scratch. v.digit
> > > > still segfaults :(
> > > > --Wolf
> > > > <:3 )---- Wolf Bergenheim ----( 8:>
> > > _______________________________________________
> > > grass5 mailing list
> > > http://grass.itc.it/mailman/listinfo/grass5
> > Jachym Cepicky
> > e-mail: jachym.cepicky at centrum.cz
> > URL: http://les-ejk.cz
> > GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
> > OFFICE:
> > GDF-Hannover
> > Mengendamm 16d
> > 30177 Hannover
> > Germany
> > e-mail: cepicky at gdf-hannover.de
> > URL:    http://gdf-hannover.de
> > Tel.:   +49 511-39088507
> Markus Neteler     <neteler itc it>       http://mpa.itc.it
> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18        -       38050 Povo (Trento), Italy
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060504/36654875/attachment.bin
