[GRASS-dev] Re: [GRASS5] "Output - GIS.m" window - what do the
icons mean?
Hamish
hamish_nospam at yahoo.com
Fri May 5 01:09:22 EDT 2006
> >>> 3. For d.rast, a printer icon pops up. What happens when I press
> >it? >
> >> The output of the command is shown / hidden. Some of the display
> >> commands output a single blank line of text, which isn't very
> >> exciting.
> > __
> > printer is misleading... what about a <| \/ triangle? or +/-
> >>> 4. Then there is a "window symbol".
> > it would be nifty if this had the Display Map window ID number
> > embossed on it, so you knew which instance you were dealing with.
> Maybe an open and shut folder??
too subtle?
Hamish
