[GRASS-dev] Re: [GRASS5] "Output - GIS.m" window - what do the icons mean?
Michael Barton michael.barton at asu.edu
Thu May 4 10:47:56 EDT 2006
Maybe an open and shut folder??
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Hamish <hamish_nospam at yahoo.com>
> Date: Thu, 4 May 2006 22:05:14 +1200
> To: Cedric Shock <cedricgrass at shockfamily.net>
> Cc: <grass5 at grass.itc.it>, <werchowyna at epf.pl>, <michael.barton at asu.edu>
> Subject: Re: [GRASS5] "Output - GIS.m" window - what do the icons mean?
>>> 3. For d.rast, a printer icon pops up. What happens when I press it?
>> The output of the command is shown / hidden. Some of the display
>> commands  output a single blank line of text, which isn't very
>> exciting.
>                                          __
> printer is misleading... what about a <| \/ triangle? or +/-
>>> 4. Then there is a "window symbol".
> it would be nifty if this had the Display Map window ID number embossed
> on it, so you knew which instance you were dealing with.
> Hamish
