[GRASS-DEV] Re: [GRASS5] "Output - GIS.m" window - what do the
icons mean?
Hamish
hamish_nospam at yahoo.com
Thu May 4 06:05:14 EDT 2006
> > 3. For d.rast, a printer icon pops up. What happens when I press it?
> The output of the command is shown / hidden. Some of the display
> commands output a single blank line of text, which isn't very
> exciting.
__
printer is misleading... what about a <| \/ triangle? or +/-
> > 4. Then there is a "window symbol".
it would be nifty if this had the Display Map window ID number embossed
on it, so you knew which instance you were dealing with.
Hamish
