[GRASS-dev] v.digit in gis.m errors
Maciek Sieczka
werchowyna at epf.pl
Sun May 7 09:04:34 EDT 2006
If no X11 monitor working, v.digit called via "Digitize map" button in
gis.m leads to an error [1], then monitor 0 pops up. Pressing "Digitize
map" once more opens monitor 1, v.digit starts - but in monitor 0.
gis.m freezes until I quit v.digit.
Another bug is that when you try to run v.digit on vector from another
mapset, you get an error [2], instead of the explanation:
"GRASS_INFO_WARNING(29617,1): A map which is not in the current mapset
cannot be opened for update."
[1]
child process exited abnormally
while executing
"exec -- v.digit -n map=poziomice_ptln_rogow >& /dev/null"
("eval" body line 1)
invoked from within
"eval exec -- $cmd $args >& /dev/null"
(procedure "run" line 6)
invoked from within
"run v.digit -n map=$opt($id,1,vect)"
(procedure "GmVector::WorkOnVector" line 34)
invoked from within
"GmVector::WorkOnVector $sel 0"
("vector" arm line 2)
invoked from within
"switch $type {
raster {
Gm::xmon term r.digit
return
vector {
(procedure "GmTree::vedit" line 16)
invoked from within
"GmTree::vedit"
("uplevel" body line 1)
invoked from within
"uplevel \#0 $cmd"
(procedure "Button::_release" line 18)
invoked from within
"Button::_release .mainframe.topf.tb1.bbox5.b0"
(command bound to event)
[2]
child killed: segmentation violation
while executing
"exec -- v.digit -n map=huharaha at wlasnosc >& /dev/null"
invoked from within
invoked from within
invoked from within
invoked from within
"switch $type {
raster {
return
vector {
invoked from within
"GmTree::vedit"
invoked from within
"uplevel \#0 $cmd"
invoked from within
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
