[GRASS-dev] Re: v.digit in gis.m errors
Michael Barton michael.barton at asu.edu
Sun May 7 10:02:02 EDT 2006
With respect to the first error, are you using the most recent version of
gis.m? I made some changes in how the button opens an x11 display on
Thursday or Friday.
I'll look to see if there is a way to trap the second error.
The fundamental problem, of course, is that v.digit needs to be re-written.
What I'm trying to do are temporary work-arounds to keep it reasonably
functional.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Maciek Sieczka <werchowyna at epf.pl>
> Date: Sun, 7 May 2006 15:04:34 +0200
> To: <grass-dev at grass.itc.it>
> Cc: <michael.barton at asu.edu>, <cedricgrass at shockfamily.net>
> Subject: v.digit in gis.m errors
> Hi,
> If no X11 monitor working, v.digit called via "Digitize map" button in
> gis.m leads to an error [1], then monitor 0 pops up. Pressing "Digitize
> map" once more opens monitor 1, v.digit starts - but in monitor 0.
> gis.m freezes until I quit v.digit.
> Another bug is that when you try to run v.digit on vector from another
> mapset, you get an error [2], instead of the explanation:
> "GRASS_INFO_WARNING(29617,1): A map which is not in the current mapset
> cannot be opened for update."
> [1]
> child process exited abnormally
>     while executing
> "exec -- v.digit -n map=poziomice_ptln_rogow >& /dev/null"
>     ("eval" body line 1)
>     invoked from within
> "eval exec -- $cmd $args >& /dev/null"
>     (procedure "run" line 6)
>     invoked from within
> "run v.digit -n map=$opt($id,1,vect)"
>     (procedure "GmVector::WorkOnVector" line 34)
>     invoked from within
> "GmVector::WorkOnVector $sel 0"
>     ("vector" arm line 2)
>     invoked from within
> "switch $type {
>         raster {
>         Gm::xmon term r.digit
>             return
>         vector {
>     (procedure "GmTree::vedit" line 16)
>     invoked from within
> "GmTree::vedit"
>     ("uplevel" body line 1)
>     invoked from within
> "uplevel \#0 $cmd"
>     (procedure "Button::_release" line 18)
>     invoked from within
> "Button::_release .mainframe.topf.tb1.bbox5.b0"
>     (command bound to event)
> [2]
> child killed: segmentation violation
>     while executing
> "exec -- v.digit -n map=huharaha at wlasnosc >& /dev/null"
>     invoked from within
>     invoked from within
>     invoked from within
>     invoked from within
> "switch $type {
>         raster {
>             return
>         vector {
>     invoked from within
> "GmTree::vedit"
>     invoked from within
> "uplevel \#0 $cmd"
>     invoked from within
> W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko
> najlepsze z nich!
> http://katalog.panoramainternetu.pl/
