[GRASS-dev] import/export projection error
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Mon May 8 11:27:43 EDT 2006
well, as far as I understand AAIGrid now, it stores one value for raster file
resolution only. If the values (nsres/ewres) differs slightly the single
resolution value in the AAIGrid export file holds a wrong resolution for ns
or ew which is only visible if number of columns/rows is high (e.g. high
resolution imagery or continental scale raster file).
It can be solved by setting g.region to the same nsres/ewsres and resample the
respective raster files before exporting the raster.
If my error detection result is correct then I would suggest that r.out.gdal
prompts a warning for AAIgrid if g.region nsres/ewres resolution differs.
Martin
On Monday 08 May 2006 14:31, Martin Wegmann wrote:
> the shift only happens for r.out.gdal export of AAIGrid not for geotiff or
> hfa.
> So far it seems that the 3 ( and upward) decimal place of the pixel size
> (AAIGrid exports only) differs from the original (and GRASS imported) file
> what causes the error on a very large scale.
> regards, Martin
> On Friday 05 May 2006 18:43, Martin Wegmann wrote:
> > Hello,
> > I just encountered a very peculiar error.
> > import of latlong/WGS84 geotif
> > import of latlong/WGS84 shp
> > border fits well
> > export of latlong/WGS84 asc/img etc. via r.out.gdal
> > load GRASS export asc into QGIS plus shp layer:
> > upper left: border fits good
> > middle left: border is shifted slightly
> > lower right: border does not fit at all
> > load original geotif into QGIS, overlay with shp layer: border fits
> > it is a continental raster/shp - perhaps only this extent makes the
> > problem visible.
> > I attached the original raster + shp and the GRASS exported raster + shp
> > in QGIS
> > if somebody wants to have the original files for testing, please feel
> > free to contact me.
> > cheers, Martin
Martin Wegmann
DLR - German Aerospace Center
German Remote Sensing Data Center
Dept.of Geography
Remote Sensing and Biodiversity Unit
Dept. of Animal Ecology and Tropical Biology
University of Wuerzburg
Am Hubland
97074 Würzburg
phone: +49-(0)931 - 888 4797
mobile: +49-(0)175 2091725
fax: +49-(0)931 - 888 4961
http://www.biota-africa.org
http://www.biogis.de
