[GRASS-dev] [bug #4426] (grass) Almost entire GRASS database
deleted. Suspect grass startup.
Hamish
hamish_nospam at yahoo.com
Tue May 9 03:07:06 EDT 2006
> Please help by suggesting what program could have done this short list
> of symptoms:
> All grass database files (vectors, rasters, regions, etc.) and their
> directories completely removed.
> Projection and other support files except for MYNAME removed. MYNAME
> still has the correct name for the location, so the whole folder
> wasn't deleted.
> WIND and DEFAULT_WIND either removed and rewritten with proj and zone
> lines or all the defaults of 0 and 1 were written to the remaining
> files.
this suggests it happened during a session, g.region creates a new WIND
if it finds that it is missing.
were you in the PERMANENT mapset at the time?
stuff to check:
$GISBASE/etc/clean_temp
I always get lots of /tmp/grass6-$USER-$$ dirs left over after exiting
GRASS, suggesting they might not be getting removed correctly.
(maybe from repeated `grass61 -gui` <cancel> ?)
e2fsck?
It is interesting that directories were removed too(?), suggesting
"rm -rf" not "rm -f", or some sort of "find | rm -f":
A while back I made a mistake coding a script which didn't check that a
g.tempfile was successfully created. At the cleanup() stage it did
"rm -f ${TMP}*", but g.tempfile failed and TMP was unset, so it ran as
"rm -f *" and wiped off all the files (but not dirs) in a home dir.
luckily my victim had a recent backup :/
I don't think common unlink() will remove dirs.
Is there a map name with loc/mapset name the same as a map name?
corrupted stream of data sent to the shell? `find` files moved to
other parts of the file system?
luck,
Hamish
