[GRASS-dev] [bug #4426] (grass) Almost entire GRASS database deleted. Suspect grass startup.
Tue May 9 03:08:39 EDT 2006
> Please help by suggesting what program could have done this short list
> of symptoms:
> All grass database files (vectors, rasters, regions, etc.) and their
> directories completely removed.
> Projection and other support files except for MYNAME removed. MYNAME
> still has the correct name for the location, so the whole folder
> wasn't deleted.
> WIND and DEFAULT_WIND either removed and rewritten with proj and zone
> lines or all the defaults of 0 and 1 were written to the remaining
> files.
what happens if you try and create a new location reusing an existing
name?
Hamish
