[GRASS-dev] Re: New qgis-grass win32 build
Radim Blazek radim.blazek at gmail.com
Wed May 10 04:41:05 EDT 2006
did you find if v.buffer realy fails or only line order differ?
It should be possible with sed/awk to modify ascii output
to have each element on single line and then sort it.
Then the sum should not depend on line order.
Radim
On 5/5/06, "Sören Gebbert" <soerengebbert at gmx.de> wrote:
> Hi,
> i fixed some bugs in the test suite. (im sure there are still a lot of
> them.....)
> Now it runs without problems within the MinGW32 environment on my machine.
> The test
> suite:
> http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/GRASS_Testsuite-0.2.0.3.tar.bz2
> The html output i have generated:
> http://www-pool.math.tu-berlin.de/~soeren/grass/GRASS_TestSuite/html/MinGW32/
> A screenshot of the test suite running database, general and raster tests
> within
> MinGW32:
> http://www-pool.math.tu-berlin.de/~soeren/grass/modules/screenshots/QgisGrassMingw-TestSuite-Result-db-general-raster.png
> Happy testing ;)
> Any suggestions and bugreports are welcome!
> Soeren
> Echte DSL-Flatrate dauerhaft für 0,- Euro*!
> "Feel free" mit GMX DSL! http://www.gmx.net/de/go/dsl
