[GRASS-dev] Projection-problem
Paul Kelly
paul-grass at stjohnspoint.co.uk
Thu May 11 07:35:46 EDT 2006
Hello Stephan
On Thu, 11 May 2006, Stephan Holl wrote:
> But, it does not import any other projected dataset anymore unless I
> specify -o which mostly is unintended for projected data.
> # Reimporting
> v.in.ogr dsn=/tmp layer=spear_roads out=test2222
> ERROR: Projection of dataset does not appear to match current location.
> LOCATION PROJ_INFO is:
> datum: nad27
> nadgrids: conus
> proj: utm
> ellps: clark66
> a: 6378206.4000000004
> es: 0.0067686580
> f: 294.9786982000
> zone: 13
> cellhd.proj = 0 (unreferenced/unknown)
> ^^^^^^^^^ Wrong!
Hmm I don't see how the change I made could affect that at all. What does
g.region -p
say?
I should also say that the projection comparison code is "just there", I
don't like it, don't think it is a good way of testing things nor very
robust/comprehensive, but there is no better way of doing it so it stays
there!
Paul
