[GRASS-dev] Projection-problem
Stephan Holl
holl at gdf-hannover.de
Thu May 11 09:22:55 EDT 2006
Hello Paul,
On Thu, 11 May 2006 12:35:46 +0100 (BST) Paul Kelly
<paul-grass at stjohnspoint.co.uk> wrote:
> Hello Stephan
> On Thu, 11 May 2006, Stephan Holl wrote:
> > But, it does not import any other projected dataset anymore unless I
> > specify -o which mostly is unintended for projected data.
> > # Reimporting
> > v.in.ogr dsn=/tmp layer=spear_roads out=test2222
> > ERROR: Projection of dataset does not appear to match current
> > location.
> > LOCATION PROJ_INFO is:
> > datum: nad27
> > nadgrids: conus
> > proj: utm
> > ellps: clark66
> > a: 6378206.4000000004
> > es: 0.0067686580
> > f: 294.9786982000
> > zone: 13
> > cellhd.proj = 0 (unreferenced/unknown)
> > ^^^^^^^^^ Wrong!
> Hmm I don't see how the change I made could affect that at all.
I don`t understand this at all!
> What
> does g.region -p
> say?
Thats what it says...
g.region -p
projection: 1 (UTM)
zone: 13
datum: nad27
ellipsoid: clark66
north: 4928010
south: 4913700
west: 589980
east: 609000
nsres: 30
ewres: 30
rows: 477
cols: 634
Strange. Everything should be right.
> I should also say that the projection comparison code is "just
> there", I don't like it, don't think it is a good way of testing
> things nor very robust/comprehensive, but there is no better way of
> doing it so it stays there!
Yes, no problem at all.
Ahhh, I found out:
# show layers in folders
v.in.ogr -l dsn=/tmp layer=spear_roads out=test5
Data source contains 3 layers:
spear_roads, flst_gef, NSG_Beispie
EPSG:26713 EPSG:31467 EPSG:31467
# now import
v.in.ogr dsn=/tmp layer=spear_roads out=test5
ERROR: Projection of dataset does not appear to match current location.
datum: nad27
nadgrids: conus
proj: utm
ellps: clark66
es: 0.0067686580
f: 294.9786982000
zone: 13
# different syntax
v.in.ogr dsn=/tmp/spear_roads.shp out=test5
A datum name nad27 (North_American_Datum_1927) was specified without
transformation parameters. WARNING: Non-interactive mode: the GRASS
default for nad27 is towgs84=-22.000,157.000,176.000.
Projection of input dataset and current location appear to match.
Proceeding with import...
[successfull import]
The first syntax fails, if the datasource (the folders the shapes are
in) shapefiles with different projections reside in.
No problem, if you export heaps of spearfish-shapes, but put another
shape with e.g. EPSG:4326 inside and you will fail to import the
dataset with the second syntax.
This seems to be a bug (if anybody can confirm of course)
Best
Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
